05 2500 GMC |
Post Reply |
SteveMaskey(MO)
Orange Level Joined: 11 Sep 2009 Location: Wellsville, MO Points: 590 |
Posted: 11 May 2019 at 11:45am |
Got a 05 GMC 2500HD that wears the rear tires out fast. Cant see anything wrong any ideas? Less than 10,000 miles and no I am not drag racing. Truck has 125,000 miles on it now had 100,000 when I bought it. 2 sets of tires
chaskaduo
Orange Level Joined: 26 Nov 2016 Location: Twin Cities Points: 5203 |
Alignment off, Frame Tweaked, Axle Shifted comes to mind.
DMiller
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29594 |
Broken spring or sheared center pin or spring eye bushings worn out.
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3894 |
That should have a 14 b full floater rear jack it up pull the axles and check the rear wheel bearings. You won't find a bad one with the axle shafts until it's bad enough your needing spindles next. Spring centering pins and spring bushings should make it dog track but not increase tire wear. Wheel bearings will cause cupping like a ball joint does on the front. Or maybe your just running overloaded or under pressure. A 2500 should be running load range E tires with 60-80 PSI.
HD6GTOM
Orange Level Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
Steve have someone else drive it down the highway. Follow them and see it it dog tracks. I know you are not in Iowa, but the absolute very best folks we found to figure out suspension problems with cars, trucks, vans, etc. Merrill Wheel and Axle in Des Moines Iowa. They are the people that dealers take problem vehicals to when their people cannot figure out the problems. I sent several customers to them.
Red Bank
Orange Level Access Joined: 18 Apr 2018 Location: Germanton NC Points: 1049 |
If it has limited slip differential make sure it’s not locked in all the time. I have seen on Ford F250s the clutch packs seize up and won’t unlock in turns wearing tires out faster
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13611 |
yep...all of the above
SteveMaskey(MO)
Still haven’t found anything wrong. Bearings seem to be good, no broken springs and the hangers look good, didn’t take apart but the center pins look right and doesn’t look like it has shifted. I don’t know it has limited slip differential could not find a tag but when jacked up with trans in neutral you can turn 1 wheel easy. Tires are 265/75R16 load range E and had 50 lbs air. Truck is empty 90% of the time. Drivers side is wearing even, passenger side is wearing on one side both sides are wearing too fast. I also checked for rim trueness. Thanks for all the help
OldSchoolRecovery
Silver Level Joined: 06 Nov 2015 Location: Eagle River, WI Points: 301 |
What brand tires? I have a 07' GMC 2500HD and when I bought it from my cheapass brother, he had fleetfarm or walmart tires on it, whichever, was the cheapest at the time. The truck rode hard and the tires looked like junk with uneven wear, etc.
I replace the tires with Cooper tires and they are wearing great. They were a little squishy at first, but that was because I was comparing them to the rocks that were one the truck. I am used to them now and like them a lot. I run 50 in all four, unless pulling my equipment trailer or hauling something heavy in the box, then 80. When I do get new tires on my car or truck, I have them do an alignment. They may be able to tell you as they do all four wheels. Also, rotate your tires. While I'm guilty of not doing that as recommended, in your case you will extend the life of all the tires, instead of just burning one up. My thoughts, Carl Edited by OldSchoolRecovery - 12 May 2019 at 8:13pm |
mhankins
Silver Level Joined: 19 Feb 2019 Location: Arkansas Points: 134 |
With it on level ground,lay a level on the wheels and see if they are standing straight up. Had a 76 chevy one time that the axle tube was bent. A 4 wheel alignment machine would be a good diagnostic tool.
allisrutledge
Orange Level Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1352 |
Shocks, brake lines and calipers
chaskaduo
Gas pedal.
Red Bank
It’s a Chevy |
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
If the side that is wearing fast is the side that turned harder when you had it in the air and in neutral then it has to be a brake dragging, wheel bearing or a bad differential causing it.
1957 WD45 dad's first AC
SteveMaskey(MO)
Update on truck. I took it to a place that does 4 wheel alinement and the rear end is bent. Will have to replace to fix it over ½ inch toe end
Red Bank
Sorry for the bad news but thanks for the update
chaskaduo
Where are all the Ford and Dodge guys? I thought they would be in for the kill by now.
Edited by chaskaduo - 06 Jun 2019 at 3:32pm |
OldSchoolRecovery
Not great news, but now you know...
Carl |
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8018 |
How do you bend a 3/4 ton axle hsg?
shameless dude
jumping terraces
Sugarmaker
Orange Level Joined: 12 Jul 2013 Location: Albion PA Points: 8168 |
chas,
We try to be easy on the Chevy guys. They have enough problems without us bothering them! Regards, Chris
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11398 |
SteveMaskey(MO)
To answer SteveM question the shop said it was probably overloaded or wrecked. I crawled around under it and could not see any evidence of it being wrecked and it does not have a salvage title. This happened before I bought it and is probably why previous owner got rid of it
TimNearFortWorth
Orange Level Joined: 12 Dec 2009 Points: 2014 |
Steve, you may want to consider replacing ALL leaf spring mounting bushings as this would be the ideal time to do it.
I picked up a 2007 2500HD 2WD cab & a half short bed with over a 100K miles for use on the farm some years back and it sat for over a year in the shop until I had a new CM bed put on it for general use including gooseneck trailering. Always bugged me that it had a slight "clunk" when leaving a light and my fear initially was a worn out rear as uni joints were tight and lubed. Called a truck suspension shop in Fort Worth, relayed the symptoms and he chuckled before telling me that if the rear end was not clunking by binding on short corners, "run it as that GM rear will likely outlast you". Advised the spring mounting bushings were likely worn in and the GM's were known for this. Ran it by a friends shop for him to watch the rear when put into drive from park. Sure enough, you could see a small amount of play in worn bushings and he advised he had seen many do it and GM eventually changed out the material for these bushings. Had me view it while he moved it from park into drive and then asked me if I ever felt it with the stock trailer or flatbed gooseneck or bumper pull trailers hooked up, even empty. I realized then that it was less obvious after installing the flatbed as it was heavier than the stock bed. Picked up 10 sacks of feed (500#) on the way home and sure enough, just enough weight to get the rear springs in a little bit of tension at the bushing area and no noise made at all. Same with any of the trailers as just the hitch weight takes care of it. Have monitored/rotated the tires throughout as nearly new when I bought it and they have worn evenly and normal wear with over 50K miles now. Only thing I have done is add a can of BG to the rear diff and clear the rubber vent tube so she can breath and she has been on a number of long trips including trailering without issue. Best of luck on gettin your ol' gal straightened out. |
Post Reply | |
